Engine won't start but turns over. 4 cyl with 8 spark plugs all eight produce no spark while cranking.
I have an 1989 ford ranger xlt 2wd 4 cyl. During the crazy cold spell here in northern Kentucky it wouldn't start and I attributed it to a bad battery(which was bad). I have changed the battery and the temperatures have returned to their normal 30 - 40 F range but the truck still won't start.
Things I have checked:
  1. I checked to see if the timing was good. No problems there.
  2. Crank sensor/Harmonic balancer. Everything checked out. assumption was wrong
  3. All not-inline fuses. Both panels in the cab and under the hood.
  4. Tested the ignition control module.(bench tested)
  5. Fuel system(inertial switch , pump, starting fluid...)
I have not went through and checked all of the inline fuses for continuity. Does anyone have any leads on what may be causing this and possibly a fix?
Felix Castor
  • 193
Bad crank sensor
Well, it turns out that the 2nd bullet on my list of things not wrong was incorrect. I had "assumed" that the crank sensor was fine because I had just put a new one in not 3 months ago with a brand new harmonic balancer. Plus it looked perfect as far as a visual inspection. No odd wear or corrosion just a little soot built up on the magnets.
Without much else to go on, I pulled the crank sensor and swapped it out for a new one since it was under warranty. It fired right up yesterday and seems to be running fine.
Felix Castor
  • 193
