I want to know how can i manually start my Malfunction Engine Light (Check Engine Light) ? i actually want to generate a DTC so that i can see it on a OBD Scanner. I know even altering or removing/cutting any sensor will probably generate a DTC but i want a solution which is easy, doesnt require any cutting and DTC is generated fast.
user3098378
  • 141
The easiest thing I can think of is to remove the gas cap and start the engine. You should quickly see a MIL. The scan tool should report something like Evap emission fault large leak.
mikes
  • 20,121
  • 27
  • 50
The gas or petrol cap is a good idea. Removing the coil pack(s), on cylinder 1, is another one.
Sometimes you can easily find an electrical connector - say the O2 sensor - and disconnect it. This, of course, depends on what connectors are easily reachable. On a Hyundai Coupe, the O2 sensor is easily accessible.
Nick
  • 1,945
  • 20
  • 30
