10
This is a curiosity question. I recently had the timing belt, tensioner and water pump replaced on my Honda Odyssey.
When I picked up the van it was really hot inside but I didn't think much of it. Later I turned on the climate control and noticed the mechanic had set it to 34c and apparently ran it long enough to really heat up the interior.
Is this a standard test of some kind related to either the coolant change or the other items that were serviced? And assuming it is, what is the goal?
Cameron Roberts
  • 783
  • 18
If the cooling system is drained, it needs to be refilled and all air needs to be removed. The mechanic turns the heater on to allow coolant through the heater core to be sure all air is being removed. It's part of the burping process.
Jupiter
  • 3,510
