I hade a misfire in my propane burnisher (buffer). The Exhaust valve is stuck and wont move, as a result the push rods bent. Manufacturer recommended I get a new head. I replaced the head according to the instructions. New gaskets, new push rods, all bolts torqued to spec. The gap between the rockers and valve springs are gapped correctly. Yet I'm getting 120-130psi compression in the cylinder, where spec is 60-70psi. I've checked the head part number and engine model number and it all matches. The old head and new head look identical besides the carbon on the old.
I haven't tried it with any fuel because I'm scared of pre-ignition and ruining the head again.
Any ideas on why I'm getting high compression?
Engine: Kawasaki FS48V-ES10 Burnisher: PE400BU
Edit: For further context, Cylinder 2 is within compression spec. It was tested before and after the head on Cylinder 1 was replaced.
Bondark
This is only a partial answer:
You could narrow down your diagnosis by comparing the volume of both heads. If both volumes match, then the new head is fine and your problem lies somewhere else.
How to measure the volume of a cylinder head.
  1. Remove head. Attach spark plugs and valves, without rocker arms or camshafts, so that all the valves can be closed.
  2. Insert a layer of grease between head and valves and close the valves. You now should have a fluid-tight "pocket".
  3. Place the head head-down, so that the opening is at the top and the spark plug is at the bottom.
  4. Place an old head-gasket on the head. Bolt on a plexiglas plate over the gasket. The plexiglas plate has two small holes, just enough for a syringe needle, over each combustion "pocket". One hole is for inserting the measurement fluid, the other is to allow the air to escape. The smaller the hole, the more accurate is your measurement.
  5. Use a syringe to fill the entire "pocket" with some fluid (diesel, soapy water etc..) until the pocket is bubble-free full. Write down how much fluid is needed to fill the pocket for each cylinder.
Martin
  • 8,644
  • 27
  • 41
120 to 130 psi compression test result is within the serviceable range of a typical spark ignition combustion engine running on unleaded pump fuel.
However a spark ignition combustion engine powering a specialised machine/tool set up to run on propane with a low compression ratio will have an oil ring designed to manage engine oil that would otherwise be subjected to the solvent effect of unleaded fuel.
If however your engine has been run on unleaded with an inital compression ratio of 60-70 PSI the reason your seeing a test result of 120-130psi will likely be due to a build up of engine oil, unburnt fuel and carbon in the piston ring lands and between the crown of the piston and the top compression ring. a build up of this tacky material is likely the reason the exhaust valve hung open.
Can you provide the source recommending a compression test result of 60-70psi as serviceable?
