-1
I have a K13 nissan micra 2014, it comes with a engine immobiliser that has a chip in the key. I am from a Electronics background so excuse any mistakes i make, but would like to be able to start it remotely and as well have push button start. For this i would like to bypass the immobiliser. From what i can tell it reads the data off the chip and sends it to the ECU. Could i rig a microprocessor like a arduino to just send the same data to the ECU and if so how would i go about doing that.
Also how could i bypass the wheel lock.
if not can how could i go about getting this done while being safe.
Thanks
It seems you want to make a bypass with a loophole? aren't you afraid that your car could be stolen in the same way? or are you trying to get the neighbor's car? :|
The way you ask to bypass the wheel-lock, bypass immobilizer is concerning me.
You can however to create a similar device (wheel lock and immobilizer) with your own program and Arduino. But you need to understand basic programming in Arduino, and electronic.
However, for bypass-ing the original device, you need to understand how to reverse engineering. And I must say this is un-ethical which you can do an unresponsible thing or two.
This question is similar to you asking "how to hack Facebook" is pretty much hilarious.
Cubic273.15
  • 377
