Mini Bike coleman ct200u wont start i bought it off facebook market place i went to look at it he says it takes usually 3 pulls for it to start and he showed me the choke off gas on and kill switch facing forward he started it took it for a little spin brought it back i took it home and it no start could it have to do something with me taking the front tire off trying to put it in the car?
Have you cleaned the carb maybe the jets are blocked change the spark plug check the tank maybe the fuel has been sat awhile and don’t be scared to really pull the string not all the way out or you will break it be strong the pullback could be it trying to start but not enough momentum
If it has a kill switch maybe the problem
Or the spark cover is not on properly
Some times different weather can change the bikes performance (hot day No air) humid, it will need to be adjusted on the carb can be a air screw, or a fuel screw, probably not the problem
3 thing
Spark Fuel Oxygen
If one of these is out you will have a problem
To much fuel Black and wet spark plug, if running excessive fuel being spat out the exhaust, back fires Running too rich
Spark or no spark, maybe a weak spark plug or the CDI
Oxygen if you breathe too much on the bike you will then steal the oxygen from the bike so hold your breath, kick start or string GO MENTAL untill it starts and then breathe again If failure to START throw object on floor and tell it you mean nothing to me,
- 1
- 1
