We've got a 2018 Hyundai Tuscon and we've recently noticed that it takes a long time to get going from a stopped position once the car is warmed up. First thing in the morning when the car is cold, it drives fine, but once the temp gauge gets to 11 or 12 o'clock, accelerating from a stopped position takes an extra 1-2 seconds before the car actually moves. This feels especially scary when making turns at red lights because it looks like we are just rolling cluelessly for 2 seconds.
There are no engine lights or codes being alerted.
If I use the sport shift mode, and keep the car in first gear, the problem happens consistently. It is not starting in second gear.
In neutral, hitting the gas hard immediately shows high RPMs so I assume it's the transmission.
We recently had an (engine) oil change at the dealer where they used some kind of "extended oil treatment" which is said to help "expand the seals and extend the life of the oil change", etc. Car has less than 20k miles.
Why would this sort of thing happen only when the car is warmed up?
JacobIRR
  • 153
Take the car into a dealer/certified Hyundai repair shop and ask them to check (or replace) your Boost Pressure Sensor Harness.
I had this same problem in my 2017 Hyundai Tucson Sport, if I'm understanding you correctly. When I would try to accelerate, the engine would rev up but no acceleration would be applied for about 1-2 seconds, which felt very scary in situations you describe or driving in icy/snowy conditions, for example.
When I took the car in to have this problem identified, the mechanic told me the Boost Pressure Sensor Harness was loose/faulty and was either repaired or replaced. Since then, I have not experienced this issue at all.
TylerH
  • 121
Just a random thought: I recently test drove a Hyundai and the start\stop feature on it had a very slow reaction time. Does yours have this feature and if so, try turning it off on your next trip and see if the problem goes away after it warms up.
Jupiter
  • 3,510
