I can't figure out how to select variable speed belt for our variable speed drive design with the following specifications of our BAJA vehicle: 1.) BHP= 10HP 2.) Max. Belt velocity = 35 m/sec 3.) Max. Engine RPM = 3700
We are designing this variable speed drive for our CVT. Any help regarding the description of selection process will be greatly appreciated.
Thanks in advance!
So, simple analysis is:
max belt speed <= engine speed * gear circumference
Throwing in the numbers and solving for the diameter at the maximum point:
Edit based on a unit error...
D = 35 / ((3700/60) * 3.14159)
which gives 0.18 metres ie 18cm.
That should enable you to work out what you want to use for a final drive ratio..
Solar Mike
  • 34,681
  • 30
  • 59
