Started up fine the first few times but when you hit the throttle it went wide open and when you let off the throttle it stayed wide open, so my son had to hit the kill switch to stop it. After doing this about 5 times it would not start back up. I figured out how to adjust the throttle to work properly, now it will not start. Did we damage something by hitting the kill switch while it was going wide open?
DavidRecallsMonica
  • 3,685
  • 19
  • 31
Bob
It seems unlikely that shutting it down caused any damage. More likely your carburetor is clogged up from old gasoline.
Take it apart and clean, or more likely replace, the jet, the venturi tube, and the float valve. If the bowl is gummed up, clean that out too.
jwh20
  • 12,187
  • 17
  • 27
