Question about the tensioner assembly for my 2003 Corolla. At 99,000 miles Toyota replaced the assembly. This week, after a routine inspection, the same Toyota service shop suggested replacing the tensioner (leakage, according to the advisor) and timing cover gasket. At a much higher cost, of course. My Corolla now has 116,000 miles. Should I expect the tensioner to need replacing at 17,000 miles?
Asked
Active
Viewed 1,395 times
The closest I've seen to problems with the tensioner assembly is oil leaking:
http://www.paulstravelpictures.com/Toyota-Corolla-Timing-Chain-Tensioner-Oil-Leak-Repair-Guide/
If the Toyota service shop already repaired it, I would have a conversation with the manager about what he/she thinks they might have done wrong during the first repair to make the second repair necessary.
NL - SE listen to your users
- 488
- 5
- 17
Sounds like nonsense. My corolla has 170 k on it and no problems with the tensioner. I know you asked this question a long time ago but new readers may benefit.
John
- 9
- 1
