I have a 2015 Cadillac Escalade luxury 4wd with 6.2 regular gas. I changed 2 injectors but by mistake the 2 i installed are high flow and the correct one should be low flow what is the worst that csn happen if i leave like that?
Asked
Active
Viewed 50 times
Two of your cylinders will run rich due to more fuel being added than the ECU expects. This could cause numerous serious problems. For example -
- The catalytic converter will work harder to burn the unburnt fuel. Maybe causing the Cat to burn out.
- The ECU may recognise the rich exhaust caused by the 2 new injectors and weaken the mixture. This could make your correct injectors run weak causing high temperatures in the other two cylinders leading to burnt pistons and valves.
HandyHowie
- 25,681
- 3
- 40
- 76
