I have noticed an issue today when driving and was hoping someone might have some ideas. Car is a 2008 PEUGEOT 207.
I have noticed that sometimes when I floor the accelerator at 4th and 5th gear, the RPM will shoot up to 3-4 rather than the usual 1-2 but the speed will not increase in tandem. This does not always happen and seems to be random. If I bring the accelerator back up and then gradually increase the speed, it tends to be fine.
From what I've seen online, a lot seems to indicate as to a slipping clutch or something. Would I notice any other symptoms if this was the case? The clutch feels normal and there is no grinding noise, nor no odd smell which I've seen people say are also symptoms of a slipping clutch.
I know I have a leaking CV Boot (leaking grease into the passenger side wheel). It's due to go into my mechanic this week - could this be the cause of my problem?
Thanks in advance.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Jordan
Most likely the problem is the clutch and it's slipping quite severely. This is a classic symptom of this problem, with or without the smell associated with it. When a clutch is fully engaged, it should be a very linear RPM to speed movement, meaning, as the RPMs go up, so should the speed. If the RPMs shoot up and the speed doesn't, something is slipping. This could either be the tires roasting on the pavement or the clutch not gripping as its supposed to. Since you didn't mention doing donuts, I'm betting on the slipping clutch.
The CV joint would have nothing to do with this. If the CVJ quit working, your car wouldn't move.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
