My ford focus 2005, Zx3 has been acting up running real rough turning off from time to time, I bought an OBD2 scanner and the P0172 code came up. I changed the fuel filter and the car ran good for about a day or so, then the idling issue started again. I'm wondering if you can tell me what this data means. I'm getting a Too Rich Bank 1. I know I have to do a smoke test, but I'm concerned about how to read this data. I researched the fuel pressure, and supposedly Ford's Focus fuel pressure varies from 25-65PSI for fuel pressure, i'm idling and the fuel is at 39.7, or I think frp = Fuel Rate Pressure. Can you help me read this data as I have too much fuel, and not enough air.
View Freeze Frame
DTCFRZF           p0172
Load PCT %        36.5
ETC(f)            149
Shift1%           36.7
LONGFT1(%)        -26.6
MAP(inHg)         8.5
RPM (/min)        926
VSS(mph)          0
SPARKADV          8
IAF (f)           70
MAF(lb/min)       .464
TP(%)             17.3
AIRSTAT           OFF
O2BS1             .180
SHRTFTB1S1        35.9
O2B1S2            .645
SHRTFTB1S2        99.2
O2B2S1(V)         0.00
RUNTM(SEC)        83
FRP (PSI)         39.7
EGR_PTC(%)        .8
FLI(%)            31.80
WARM UPS          2
CLR DIST (MILE)   12
BARO(IN HG)       29.4
CATEMP11          942.26
LOAD ABS          18
EQ RAT            .999
TP_R (%)          0.00
AAT (f)           61
