General Info:
- Car: Nissan Murano 2005 SL
- Crank + start: Yes
- Battery charged: Yes
- Battery terminals correct install/uninstall order: Yes
Problem:
No power on ACC position, no ignition key warning sound, no ignition key light, no dome, map, rear interior lights, no rear windshield wiper.
Works:
Radio + dash on ON, windows, front windshield wiper, lock/unlock, door window buttons.
Note:
So my old battery got drained because I was messing around in the car for long without engine ON, and then since it wouldn't start, I jumpstarted the old battery to make sure that it was the problem. I replaced the battery with a new one, now all these problems started to occur. I should note that my friend was the one who jump started the old battery, so I'm unsure whether he followed the correct jumper order.
Additionally, when the key is on ACC, nothing in the dash lights up, I have to turn it into ON so the radio + dash turn on.
I have checked the fuses (using multimeter - continuity test), but not the relays.
This is the last fuse box which I have not throughly* checked, as accessing it has proven difficult. Is there any fuse(s)/relay(s) here that may be causing the problem?
