Went to start the car today but noticed straight away that the handbrake leaver hasn't got any tension on it at all - can pull it up and down with one finger. Thought i might have a snapped cable and was going to take it to the local garage... When I went to pull away I heard a stretching sound as if the handbrake was still on? Tried a few times to slowly pull away but it sounds like the handbrake cable is still engaged and would snap if I try to pull away.
Would anyone have any idea what's happened and what the solution would be?
It's a 2009 Renault Mégane expression vvt 1.6
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Kris
If I should guess, I'd say your handbrake cables are both frozen.
There are two steel cables running from the hand brake lever to each rear brake, acting on a small lever there. And there is a small spring on each brake pulling back the cable.
The tension you feel comes from that spring, and from the inner tension of the brake.
  • If the cable or the lever on one wheel gets seized all of a sudden, then that leaves you with an activated brake on that side, and a very low tension (less than 50%!) from the other side.
  • If it seized slowly over time, you'll have the same effect on the lever, but the brake on that side does not work - even if you pull hard. The very low tension
  • If a cable snapped, it would be the same as #2.
  • If both sides get seized all of a sudden, there will be absolutely no tension on the hand brake lever. And if both brakes are active, and it's below freezing, chances are high that the cables are just frozen in their cladding.
sweber
  • 7,067
  • 24
  • 43
Sounds like the cable is seized. If you can't move the car, you'll have to have it towed to a shop.
user9181
  • 1,392
