('07 Cobalt LS, 2.2 L)
Re the passenger side engine mounts, ... The Alldata manual (AIUI, from Helm) says
  • Tighten the engine mount to body nuts to 66 N.m (49 lb ft).
  • Tighten the engine mount to bracket bolts to 130 N.m (96 lb ft) plus 45 degrees
But, specs posted elsewhere, credibly said to be from GM Global Connect say ...
  • Engine Mount to Mid-Rail Nuts 100 N.m
  • Engine Mount to Intermediate Bracket Bolts 50 N.m
These seem seriously different, esp 50 Nm vs "130 Nm + 45 degrees".
Does anyone know? Has anyone done "130 Nm + 45 degrees"? It seems like a lot.
Edit: (Not an answer) I torqued the bolts to 50 Nm, with thread locker. So far, doesn't seem to be a problem.
George
  • 1,133
  • 18
5 degrees seems much too small.. Perhaps it is a typo...
But 45 degrees is more likely, and seen 90 and 120 degrees for some bolts - depends on the design of the bolt and the "stretch" to be accounted for.
Solar Mike
  • 34,681
  • 30
  • 59
Turning my edit into an answer: I torqued the bolts to 50 Nm, with thread locker. So far, doesn't seem to be a problem.
It felt right, and it's been a couple of years with no apparent problems.
George
  • 1,133
  • 18
