My 2006 Scion XB has some problems with unlocking the doors. Sometimes when I press the unlock button it doesn't unlock the driver and passenger door. So when I try to do it manually by pulling up the lock it is jammed and doesn't not come up. After about 5 minutes if manually unlock it and it it finally unlocks. Does anyone know why?
Atticus Denewmont
  • 399
This is the second post about your car. You should state all the problems in one post for a better answer.
Check the connections in the driver side panel for the window and the lock/unlock switches. Then trace back to the fuse box and look for loose connections or loose fuses.
JACK
  • 385
