11
I've got a Mazda B2300 pickup that's started making a grinding sound whenever I come to a stop. Braking at a high speed doesn't make any noise, but once I get under 25-30 MPH, the grinding sound gets progressively worse until the truck comes to a stop. What's the most probable cause of this?
Update:
I replaced the front brake pads on Saturday and discovered that one of them had worn completely down to the backing. I had to replace the rotor as well, since there was severe wear on the mating surface.
Doresoom
  • 508
  • 22
Consider the possibility that the brakes make the noise at all speeds but that higher speeds mask it.
The most likely cause is worn pads/shoes. You should check their remaining thickness against the manufacturer's recommended minimum. (Look in a repair manual if you have one, or search the Web.) Check the thickness of the brake rotors, too.
If the car has been left to sit for a few days, corrosion on the brake rotors can cause brake noise until it is scraped off by the pads.
With some brake pads, particularly metallic or semi-metallic ones, it is normal to hear a mild grinding noise when braking.
William Cline
  • 1,833
  • 16
  • 19
if it sounds like you're grinding rocks it's probably because your CV joint has gone bad and needs to be replaced.
Sam Rosario
  • 388
