I had a Porsche engine case halves and transmission case vapor degreased by a shop run by an ex-factory mechanic years ago. He used trichlorethane, which has been replaced by trichlorethylene, N-propyl bromide or whatever for vapor degreasers. For cleaning before adhesive bonding, one "standard" combo is isopropyl alcohol and hexane, 50/50, IPA removes polar comtaminants (dirt), hexane, non-polar ones (grease/oil.) Paint thinner alone or followed by IPA is good enough. One of the best degreasers I've used is Dawn diswashing detergent, cleans well, isn't metal aggressive. Could be used after a solvent.
When I worked for an aircraft engine company, the last thing they did after testing before wrapping and shipping an engine was to spray the entire outside with trichlor out of a huge pressure washer. Worked spectacularly well, removed dirt and oils/grease. Had to be done outside with respirators. An environmental disaster and not done today.
Kind of depends on what you're trying to achieve. If you want factory clean and factory appearance, easiest route and best results would be to take your parts to a transmission or engine shop for vapor degreasing. Alkaline cleaners, detergents, soaps, etc can clean well but won't result in the same shiny new surface; they'll corrode the aluminum surface leaving a white or black residue which probably won't hurt the metal without long exposure to the cleaner or even be noticeable except compared to vapor degreased part.
Vapor degreasing dips parts in hot solvents between exposures to solvent vapors. Only consideration is making sure oil passages, etc are positioned so the liquid phase can run out; it's simple. Any other method may require small long brushes to clean passages depending on how clean you want to be. The heads will definitely need to scrubbed. If you use an alkaline/detergent cleaner be sure to do a very thorough final rinse ideally in distilled or RO water unless your tap water is below pH 7.
What's your tank made from? Polyethylene, or stainless steel, I hope. Aluminum and steel make a great battery, with AL as the anode, the terminal that corrodes. BTW, Drano is a mix of NaOH and aluminum chips. Makes a lot of gas when exposed to water, the chips churn at the clog until they corrode away in a few minutes; meaning alkaline chemicals, if aggressive enough, will eat AL rather quickly under the right conditions.
Whatever you choose, if not vapor degreasing, the important things are to limit exposure to the cleaner and rinse thoroughly with neutral water. Soaking your parts for hours or days in a cleaning bath without doing a test run first isn't a good idea. The greasy areas will come clean last, the clean areas will be corroded first. Heat and agitation will increase the cleaning rate.
Really not that touchy as long you watch what's happening while cleaning. Go for functional clean vs. beautiful clean.
