I have a 2016 rogue with 17 inch wheel I found a set of alloy wheel from a 2015 pathfinder,using a 225-60-18 inch tire everything fit perfect no issue with fender or brake or fender clearance,until I found out about wheel offset pathfinder has 50mm rogue 36mm did I make a big mistake,I can’t return the wheels is my car safe to use Ron
Asked
Active
Viewed 16 times
