Here's a strange situation I encountered last night that I'm trying to wrap my head around.
My mother in law drives a 2011 Subaru Legacy. Last night, her battery (since replaced) died -- not totally dead, but no longer had enough power to fire the starter.
I brought my wife's car, a 2018 Chevy Traverse, to provide a jump. I made the negative connection on the provided ground post rather than to the battery. When I made the final connection, the entire electrical system on the Legacy went dark -- lights, accessories, everything. As soon as I disconnected the jumper cables, everything came back. During this time, the battery voltage reading on the Traverse was reading around 14 volts.
Unable to successfully jump, I swapped cars and brought my car, a 2006 Kia Spectra, and repeated the process. Everything worked as it should.
My question is this: what was going on that the jumper cables from the Traverse made the Legacy go completely dead? And what was different that it didn't happen when I used the Spectra? The polarity was correct, both cars work properly, no fuses were blown. I'm at a loss to figure out what happened.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Tristan
  • 121
One of two things happened:
  1. While you were attaching the jumpers to the Legacy, you dislodged the connection and caused it to go black.
  2. You attached one side or the other backwards on the initial attempt, causing a short, rather than a jumper circuit.
I'd suggest your issue was actually #2. Since there was a lot less juice in the Legacy battery than what the Traverse was putting out, the Traverse just overrode the Legacy causing the blackout. When you brought the second vehicle in to jump, it was then connected correctly and things worked as they should have.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Your mother in law quite logically turned the lights off SOS all available power would go towards recharging her battery.
Bob S.
  • 120
