Ducati 450 scrambler 1975 converted to 12v with Luas Rita AB11 electronic ignition it is so easy to start with this modification I put a new original alternator 3 face that gives up to 55v at 5000rpm a new original reg/rec output 14v and the problem it is not charging the battery do you think that I have to do a diode after the battery or something?
Thank and I appreciate for help.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
So a “new original” alternator - 6v or 12v..
You put a 12v ignition system so the battery needs to be 12v and so does the alternator and the regulator.
If those things are mis- matched then they won’t work, it seems lucky that it runs.
Solar Mike
  • 34,681
  • 30
  • 59
