Water is leaking into the driver's side footwell on my 2008 Ford Ka.
Any ideas on where to start looking to stop this happening? I assume it could be a bulkhead seal/grommet has failed perhaps ?
There is no water leaking into the passenger footwell, only the driver's side.
It's quite a lot of water - if I push the carpet down, water comes up.
It's causing large amounts of condensation on the inside of the windscreen as well.
It is definitely a water leak, not coolant.
DavidRecallsMonica
  • 3,685
  • 19
  • 31
Aycee
The places to start looking are:
1) the floor: water gets thrown up and comes through the hole...
2) bulkhead seals and around the wipers / under the shield between the windscreen and bonnet...
3) Windscreen seal, top, side and bottom as the water can run around and then drip down behind the dash...
Finding it: well, we would have one "making rain" with a hose, flooding the roof, windscreen and bonnet while the other looked with a torch to see where the water was coming down. Sometimes removing the carpet was necessary just to see where the water tracks started...
But, you will probably need to remove the carpet to get it dry quickly anyway.
Solar Mike
  • 34,681
  • 30
  • 59
