Bought a used katana gsx600f 2006.cannot get it to turn over.battery good, Clutch lever engaged,kickstand up,push starter button,starter solenoid not clicking. Can short over relay & motor turns over.
Asked
Active
Viewed 710 times
Bought a used clutch lever with cable that you just pull off old & bolt this replacement. Diassembled old assembly & found someone previously changed out clutch lever only so all broken safety switch was still installed. Diassembled sidestand switch. It was corroded beyond repair, so will buy new one.
user43741
- 41
- 3
-2
check to see if your plugged in to the clutch lever. i had an issue and that was the problem.
Travis
- 32
- 2
