The tires on my G6 are 225 r50 17. One of them blew out today and I have fairly new tires on my Saturn that I'd like to swap. The Saturn tires are 215 R55 16, would I be able to use these tires?
I'm going to eventually switch them back to the Saturn when I sell it, so this wouldn't be perfect. Just trying to save a bit of money for the next few weeks.
Thanks
Dustin
The short answer is maybe. The rims may not be compatible, even though the bolt circle (5x110mm) is the same.
However, I'm showing an ET42 offset on the G6 with 17s, and ET45 offset for the L300.
That may not be enough difference to matter. The L300 tires are also over a half inch smaller in diameter, which makes for an additional 17 revolutions per mile. There will be a 2.5% error (approx) in your speedometer and odometer.
I can't recommend such a swap without evaluating all clearances at all steering angles, but the 3mm offset difference in the rims is likely negligible.
SteveRacer
  • 12,432
  • 26
  • 47
