My Suzuki Gixxer 155 is making a weird grinding whirring noise. The noise is there when the clutch is open. As soon as I pull the clutch the noise goes away and there is no noise in neutral too or while idling. Also, I think the grinding noise increase when I put 5th gear to lower gear, say 2nd or 1st gear. but when I stop my motorcycle and start from 1st gear, less grinding whirring noise. I know when you put 5th gear to first gear there will be noise, but mine seems to be grinding and whirring. What might be the problem here?
Asked
Active
Viewed 559 times
