Car is a civic vti 1999.
I've asked on forums and honda themselves who said so long as my weather isn't extreme one way or another, I should use 0w30 or 5w30 engine oil.
When I went to pickup the oil from my local parts store they told me I need to be using 10w40 because my car is old and showed me some specific oils. When I said honda said he replied '..well they would because they want to sabotage your car. older cars do not do well on the new stuff they will put strain on your engine..'. I can't remember if the oils he showed were synthetic or not.
Is there any truth in this?
James Wilson
  • 2,992
  • 26
  • 81
  • 119
The reasoning behind this is that as your engine's internals wear on each other, a thicker oil would find it harder to seep through into places it shouldn't be than a thinner oil. On the other hand though, those parts that have not worn out will suffer because the thicker oil may not always lubricate them properly.
Although in both instances, that was more of a concern back in the days when there weren't such things as multi-grade and synthetic oils.
The right thing to do though is keep using the grade of oil Honda says to use, but check your oil levels every week or two. Because a high mileage engine may burn a bit more oil than a new one. Although you should hardly notice an increase in consumption. Let's say a new Honda engine burns a quart (~500ml) of oil between services. If it's really old, it may be burning two quarts. That is out of about a gallon (~4 liters) of oil you put in.
Captain Kenpachi
  • 8,888
  • 26
  • 43
