Im currently trying to get to the bottom of an issue with High long term fuel trims (+20-25% give or take) which is showing my car appearing to be running extremely Lean, struggling with this as the A/F ratio looks ok and o2 looks ok...
Alfa Romeo Giulietta 1.4 Multiair 2014 TCT
Symptoms are:
Slight Rough idle Idle climbs by itself to 11-1200 rpm then settles momentarily then back up High LTFT on idle of 25% When revved at 1500, 2500 the LTFT trims go back to normal STFT seem ok No fault codes Oil level is fine Air filter is fine Spark plugs look good MAP is fine o2 sensor reading looks ok? Air fuel mix is ok? Feels stuttery to drive on low revs through the gears 1-3, wide open throttle seems normal
Ive undertaken a Vacuum test and the results are:
At idle
8-10 Hg fluttering between the 2
At 1500 rpm
Drops to 3 Hg, increases to 17Hg drops to 5 Hg then settles back to 8-10 Hg
At 2500 Rpm
Drops to 3 Hg, increases to 18 Hg, drops to 5 Hg then back to 8-10 when idling
3000 rpm is the same
The MAP correlates with 68-70 kPa
Smoke test has been carried out, no vacuum leaks found
Compression test done @ 235 psi (+/- 1%) across all 4 cylinders
PCV changed as it had a slight oil leak, no changes
Adaptations reset after each test
I know the MA unit on these can be temperamental but with a solid compression ratio across all 4, i would think to rule out any hydraulic actuator issues
Any advice or experience would be welcome
Im moving onto thinking around a timing issue or exhaust blockage somewhere?
Thanks in advance
