I've got a Ford e350 (1996, 5.8L). Our front vent A/C works well, but the back blows what seems to just be vent. Not heat, but about the same temp as outside.
History:
We just recharged the A/C (by mass, after pulling a vacuum). We had to replace both evaporators since they were leaking (there's one in the front, and one in the back, working together).
Cullub
  • 1,364
  • 14
  • 37
First you run a full system leak check again.
  1. Add all new O'Rings
  2. Use the recommended PAG oil, and add the correct amount to the full system
  3. Seems like the expansion valve was not listed in the change.
  4. Get a new accumulator (Its importance is placed high, by our friend in the comments below).
Run the test now.
Lawyer Aidroos
  • 696
  • 15
