I recently watched an episode of Wheeler Dealers where they installed custom handmade 17-inch wire spoke wheels to a Lincoln Continental. The 4 custom-made wheels cost only 770 GBP for the set of 4.
This sounds like a reasonable price when compared with typical alloy wheels. Furthermore, the wire spoke wheels may even be lighterweight than alloy wheels. Consider, for example, bicycles, which is the most weight-sensitive application of them all: nearly all of them have wire spoke wheels.
Furthermore, wire spoke wheels are easier to repair than alloy wheels which must be typically replaced when damaged.
I see three advantages of wire spoke wheels here: cost, weight and repairability. This should mean that today, all cars should be using wire spoke wheels.
However, this isn't the case. Everyone today is installing alloy wheels, and wire spoke wheels are a niche. Why is this the case? Why aren't wire spoke wheels more widely used today?
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
juhist
  • 15,535
  • 13
  • 62
  • 104
I think your thinking is a bit off base as to why they aren't used, let me try to cover them:
You said you see three advantages to wire spoke wheels:
Cost
Actually if you think of the amount of money it takes to create one, you've got extra time in manufacture (individual parts), assembly (gunna be a lot of man hours), and trueing the wheel. All of these add up to a lot of money. What does it cost to to make an alloy or steel wheel? Production time is way less and most, if not all of it, can be handled by machine.
770GBP does seems like a great price. That's about $1200 in the US. I bought a set of new repop 18" C6 Z06 rims (to fit P275/35-18 tires) for a little bit more than $400. Remember, when a manufacturer makes these rims, they get mass quantity discounts, which nets it for them much less than what we are going to get on the market.
Weight
Realistically, I don't know the weight of a wire spoked wheel, but you'll have to realize, these are made out of steel. Aluminum spokes would probably not stand up to the requirements, though it would prove well in weight savings. Aluminum does not have the tensile strength steel does, so I'm pretty sure it would not be used. Both the outer and inner portion of a spoked wheel has to be built to handle the spokes, so they don't pull through, so these are going to be made of steel as well. There isn't going to be much if any weight savings over an alloy wheel.
While a bicycle may use spokes, it's because they don't support the weight a car would need to support. Rider and bike together are much less than a car in comparison. In order to support the weight of the car, the wheel has to be a lot beefier to deal. You don't have solid wheels on bikes unless you go to exotic materials like carbon fiber, but then it's cost prohibitive to the average rider.
Repairability
While you can take spoked wheels apart to fix them (replace spokes for instance), there is a bit of an art to making them right again. It takes skill to do this. It exists, but it's not cheap. Rebuilding them would more than likely cost more than it would to replace an alloy one, especially if you are a savvy consumer and were to replace a damaged alloy with a used one in good shape. Then there is the aftermarket, which is most likely cheaper yet.
You can repair alloy wheels. If they are not completely destroyed, getting them welded and machined is usually not an issue. Again, I don't have the exact costs of either, but this is very readily done today (can get it done in most metropolitan areas) at a nominal fee. Finding someone to make/repair your spoked rims would be a chore in comparison. Most likely you'd need to ship them off to make it happen.
I'll one up you on this why they aren't that popular to own today:
Maintenance
I don't know if you've ever tried to clean a set of spoked rims, but it takes some effort. It's not easy. With today's chemical cleaners, it's easier, but you still have to get between every spoke to get it clean. Five spoke alloy wheels are much easier.
Pimp-mobile Status
Really, chromed spoke wheels are usually considered (at least in the US) to be something off of a 70's era smog boat pimp-mobile. Most people wouldn't get caught dead with them on their car. Mind you, this is just my opinion, but I believe the stigma holds true.
From my point of view, the only reason you might see these on a car in this day and age is due to it being a niche market. Some people out there go for a certain look/feel for their cars. I'm not going to begrudge them that. I learned a long time ago, people make cars the way they like them. I like my car the way I like it. I'm not going to duce on someone's ride because that's what they like.
Because of the aforementioned reasons, I don't think you'll see them mass produced for cars anytime soon.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
Another reason for the popularity of solid steel and alloy rims is the development of tubeless tyres.
Spokes traditionally penetrate the rim meaning its not airtight. Meaning tubes are now necesary which have thier own limitations and drawbacks. Lower profile and wider tyres are more practical without inner tubes.
In some cases spoked wheels are still practical. Bicycles and motorcycles (especially with larger diameter offroad wheels) favour spoked rims for thier impact resistance and because they are less affected by crosswind. But spokes corrode, can snap or lose tension and retensioning and balancing is a real art form.
tubeless spoked wheels for most sizes are readily available these days as are alloy ones (not as common probably due to cost)
Sir Swears-a-lot
  • 1,542
  • 15
