Say that a friend had been silly enough to skim the text on the bottle of fuel additive, before mixing it into a full tank of fuel for his 40'000 km kawazaki z750. And say that it turned out this additive was not so much a fuel stabiliser as a lead substitute, with a clearly typed-out warning against using it on engines equipped with a catalytic converter.
How long would you estimate it would take until the cat converter was well and truly poisoned? A few minutes? Half the tank of poisoned fuel? What should my friend expect ?
I assume, of course, that he should drain the tank regardless.
edit: link to information on the additive
Dugas
  • 133
Those lead substitutes aren't one class of substances. Some have metal-organic sulfur compounds in it which are bad for the cat. Some haven't. Yours seem to be alcohol/butylether mostly, which simply increases the anti-knock rating.
The latter class of substances is most common and does not hurt the cat at all.
Janka
  • 194
For future reference:
I went ahead and emailed the additive manufacturer.
They said the additive is indeed alcohol based, and the lead substitute in this case is potassium, which while it is not recommended for cat converters, should not cause serious damage over a single tank.
They recommend driving it off, and not doing it again. I might siphon the fuel anyways as an extra precaution, though.
edit: also found this study on the poisoning of catalytic converters
Dugas
  • 133
