My car is making a sound which resembles two metal surfaces lightly scraping/scratching/grinding together at speed.
Typical Scenario: The car is very cold. If I rev the engine between 2k and 3k, I will hear the sound when I release the accelerator. The car doesn't have to be moving, nor in gear. Sound lasts 1-2 seconds when triggered.
The problem disappears when the engine has warmed up. It doesn't reappear until another exceptionally cold night.
The car: Golf MK5 GTi (2.0 turbo TFSI), 2006 model with 140k miles.
Any ideas what this might be? The fact it happens in neutral has thrown me completely.
Thanks for any help
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
James
  • 81
This sounds like the classic symptoms of the clutch release bearing failing. In neutral (and all the time in fact) the release bearing is in contact with the pressure plate fingers which causes it to rotate and, if it is failing, then make a noise.
This does mean, on most cars, taking the gearbox off...
Solar Mike
  • 34,681
  • 30
  • 59
