I need to clean off some grease from the cloating on my new rotors as well as some grease on my pads. Aside from using brakeleen, which of the three: engine degreaser, carb cleaner, acetone would work as effectively or nearly as effective as brakeleen?
Thanks
yre
  • 163
I'm not sure what "cloating" is, but nothing works as good as CRC brake cleaner.
However, given that it is banned in several states, I would start with dry paper towels to remove as much as possible, and then wipe with a clean rag wetted with gasoline. Acetone might work, but probably not as well as gasoline. Xylene would work fine as well, but again is fairly expensive.
A few hard stops should "burn away" any residue. Unless there is a serious amount of grease... What kind of grease is it, and is it just a little slop, or is it coming out of a split CV boot or something?
Dry rags and/or paper towels is where I would start in any case.
SteveRacer
  • 12,432
  • 26
  • 47
Carb cleaner is slightly less volatile than brake cleaner but essentially the same ingredients. Engine Degreaser in my experience leaves some slight residue as does acetone.
I would use Carb Cleaner in preference to the other two.
Mauro
  • 2,665
  • 16
  • 24
