My 4runner is getting "P0500 - Vehicle Speed Sensor A". What does the "A" mean? Which wheel is that?
Asked
Active
Viewed 5,797 times
This has to do with the main vehicle speed sensor (VSS), not the wheel speed sensors. It's a generic code from the P050x series. The other P050x codes are specific issues.
Symptoms of a P0500 DTC may include:
- Loss of anti-lock brakes the "anti-lock" or "brake"
- Warning lamps on the dash may be lit
- The speedometer or odometer may not work properly (or at all)
- Your vehicle's RPM limiter may be decreased
- The shifting of an automatic transmission may become erratic
- Other symptoms may also be present
Things which might be at issue are:
- The Vehicle Speed Sensor (VSS) is not reading (functioning) properly
- There is a broken/frayed wire leading to the vehicle speed sensor
- The vehicle's PCM is not correctly configured for the actual tire size on the vehicle
Pᴀᴜʟsᴛᴇʀ2
- 165,084
- 32
- 259
- 508
