I have a 1995 Acura legend and it was a project car to replace all suspension parts, bushings etc. basically I started with the rear suspension, replaced everything there including struts and bushings and then moved to the front. Due to complications it took us nearly 2 years to complete the front suspension, in which the rears were on jack stands to hold the pressure off the struts. Now (after an alignment) the rears are like 4 inches lower than the front which have oem springs, and there isn’t body roll left and right, the whole rear bounces from left to right after a bump is hit. The control arms and tie rods were also replaced so they couldn’t be bent, so what’s the problem?
sjfklsdafjks
  • 433
  • 18
The rear suspension fixings should only be finally tightened when the weight was on the wheels...
If you tightened them with the suspension fully extended then you « pre-load » all the bushes causing a different suspension response.
You could try releasing the bolts - wobbling the car side to side and then retightening the bolts / nuts.
Solar Mike
  • 34,681
  • 30
  • 59
