For some reason whenever I try to put my car into 1st gear it will grind, but if I put it in 2nd gear then into first gear quickly it won't grind. Anyone have a clue on why this is happening and how to fix it?
Asked
Active
Viewed 529 times
This can be due to the first gear synchro failing - putting it into 2nd then first reduces the speed difference that the first gear synchro has to deal with.
This should be checked by a transmission specialist as they should be able to confirm the diagnisis.
Solar Mike
- 34,681
- 2
- 30
- 59
