My scooter's stop lights have stopped working when I apply brakes, however tail light still works. I checked for a loose connection but all seems ok. It's a Honda activa
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
DhKo
  • 1,155
  • 15
  • 37
Check the following:
  1. the bulb: it has two filaments one can work while the other has failed
  2. supply to the switch: if no supply check the fuse.
  3. check the switch goes live on the output when the brake is operated.
  4. does the socket get a supply when the brake is operated - if no and you have checked the switch then there is a break in the wire to be found.
CharlieRB
  • 9,015
  • 20
  • 32
Solar Mike
  • 34,681
  • 30
  • 59
Check the combi break, may be the cables are wrong fixed, check the combi break unit. Same issues happed to me.
Janaka
