I want to purchase a straight edge which I can use to measure the flatness of heads & blocks and other such nifty things. My question is, what is considered a good tolerance for a straight edge? To make this a little easier, if I wanted to buy a 24" straight edge, how much should I expect it should be straight to across the entire length?
To confine answers, I'm not looking for what you think it should be, but rather what is standard for regular machining practices. References would be helpful.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
what is standard
DIN 874 says less than +/- 3 microns over a 300mm "sharp edged rule"
If you purchase a "straight edge" from an engineering tool company, it will most likely meet this specification.
for a "steel rule" DIN 874 defines four grades
Flatness tolerances are
  • Grade 00: 1+(L/150)
  • Grade 0: 2+(L/100)
  • Grade 1: 4+(L/60)
  • Grade 2: 8+(L/40)
E.g. in microns
           Grade
Length     00       0       1        2
0.5m       4        7      12       21
This also depends on how you support the straight edge. There are specific procedures to be followed, some procedures involve using gauge blocks and/or other specialised test gauges in conjunction with the specially supported straight edge.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
RedGrittyBrick
  • 925
