15
I am pondering getting an electric vehicle (a VW e-Golf, which is strongly rooted in the Golf "platform", just swapping the motor), and one issue amongst many is how to proceed with the maintenance. I do not have a good branded shop close by, and driving to the next brand shop to get routine (or even non-routine) maintenance would add considerable hassle. Let's ignore the issue of "voluntary warranty" (the kind that they use to force you to use their own shops) at the moment.
My naive understanding is that in an e-car, obviously the drive train is different; but I would assume that the e-motor is much simpler/self-contained than the whole gas-motor/transmission/light machine/oil/belt/...-shebang, and I would also assume that aside from the drive train, the rest of the car (in this specific example, which is based on a completely run-of-the-mill base model which should be well-known to most mechanics in my country) should be more or less the same.
Is that true? Do e-cars need "special" maintenance (regarding the "e" part) that makes it a specialist job? I assume that the battery and the motor are closed systems anyways, which may be checked through their control units, maybe, but never actually opened by any mechanic during routine maintenance. There should simply be nothing to do.
If this is correct, I could easily trust the car to my local non-branded repair mechanic; he would be able to detect errors in the motor by reading out some onboard unit (as it's done in old-fashioned cars anyways, these days), and if something bad happens, I would then, and only then, go to the branded shop.
Is that assumption correct? Or are these things more complicated than that?
jscs
  • 1,443
  • 19
  • 30
AnoE
  • 820
5 Answers5
21
Electric cars do need special maintenance, but they need less maintenance. I don't know about the E-Golf specifically but other electric cars need scheduled maintenance at around 1 year or 18,000 miles. This is on par with many newer cars with extended maintenance schedules, but much less often than your traditional 3 months/3000 miles maintenance schedules (a ripoff, don't get me started). Given that, even if your dealer isn't a convenient distance you'll only have to take it to them once a year unless you drive stupid amounts in the thing.
E Cars are very different from internal combustion cars, even if they're built on the same chassis. Batteries will go in all sorts of odd places and all the things that have traditionally been run off of vacuum and mechanical power will all have electronic replacements, like AC units, brake servos, etc. A traditional mechanic isn't going to know how to service all that, at least not yet. High capacity batteries aren't to be toyed with, if you do the wrong thing you can cause all sorts of problems, like shorts and fires. So yes, you need a specialized mechanic for now.
GdD
  • 18,048
  • 38
  • 67
When I had my electric car, the maintenance of the "standard" suspension, brakes, lights etc was by a small garage.
However, the local Dealer asked, and got, the computer and interface to deal with the batteries and charging/power/ motor unit which was good service.
The car died when the computer control unit failed - which had a 9k price tag...
Solar Mike
  • 34,681
  • 30
  • 59
Most of the regular maintenance like replacing the cabin filter or brake pads can be done by an unspecialized shop. It is still a good idea to do your maintenance at VW, even if you don't care for the warranty:
  • they will do a much better job checking for defects
  • you are likely to receive software updates
Of course, battery-related maintenance will most probably be done by VW-certified shops only.
If you need a repair, you much more likely will not be served by a generic mechanic. You'll have to go to a workshop which accepts electric cars, or to VW.
Dmitry Grigoryev
  • 2,662
  • 14
  • 29
As you are already aware, the e-golf is full electric and there isn't a traditional engine and transmission. This will reduce the costs of normal maintenance by eliminating spark plug replacement, engine oil changes, and so on. However, by removing all of those traditional services and traditional drive-train components you have limited what a traditional mechanic can do for you. You need to find someone locally who is an expert in high voltage systems. Full electric and hybrid vehicles have many high voltage components that are extremely dangerous if mishandled by someone who isn't trained to work on them. If there isn't a Volkswagen dealership in your area call around and find someone who is trained in high voltage system repair and is also familiar with the e-golf. Do this before making your purchase.
L.hawes
  • 121
My naive understanding is that in an e-car, obviously the drive train is different; but I would assume that ... the rest of the car ... should be more or less the same.
Largely true, but some definitions of "drive train" are too strict. For instance in a conventional vehicle the engine runs the power assisted braking and steering, the AC, and provides vacuum for the ventilation system and other convenience features.
In an electric vehicle these are often very different, so would require specialist care - for now.
The vehicle manual provides all the details for regular maintenance, but there will be some maintenance in some vehicles that can only be carried out through a specialized service center, such as battery replacement. This should be rare, but it will depend on the vehicle.
Generally speaking yes, and as electric vehicles become more common, particularly on the secondary market, in your area, you'll find that non-branded mechanics will be able to handle more and more of the specialty repairs.
Look at internet forums for repairs for your chosen vehicle, study the manual and maintenance schedule, ask questions about the repair history of the vehicle if it's used, and ask about specific maintenance procedures you're unfamiliar with.
Adam Davis
  • 1,597
  • 18
  • 23
