My car doesn't drink a single bit of antifreeze. It was filled 1 year ago at manufacturing time and haven't needed a refill ever since. Yet I still have perfectly functioning blower with cold/hot air into the cabin.
In fact, this is true of all of my past cars as well: not one of them was drinking a bit of antifreeze and all of them had perfectly functioning blower. In fact, my last car had the coolant never changed in the 5 and half years I owned it, and it did not need to be topped up.
I don't understand why drinking antifreeze would be required for blower working. Certainly it isn't operating on using antifreeze as a fuel!
Your blower motor or some kind of control circuit is probably broken. You could start from checking the fuses, as they are easier to replace than the blower motor. You did not specify whether your car has an automatic ventilation system or a manual one. In automatic system, the control circuit could be broken; in a manual one it is possible the resistor is broken.
So, I have identified at least three reasons:
- Fuse
- Blower motor resistor or control circuit
- Blower motor itself
Investigate these and come back later for more help if they didn't help.
