I have 2006 VW beetle with the 2.5L engine. Once the engine has warmed to operating temperature, and I am driving it around, the heater works great. As soon as I stop at a red light, or am idling for any length of time the air coming out of the vents begins to lose temperature until it blows cool air. All I have to do to get hot air again is give it a little gas, say 200 more rpms, and the heater immediately responds with warmer air, hot air if I maintain 1000 rpms. I have read related information on here and think that if the heater works great at other times, I do not have a blender door issue, clogged heater core, or low coolant level. The coolant level is fine, by the way. Any help would be greatly appreciated!
Asked
Active
Viewed 1.2e+01k times
Problem solved! The key was to finally locate the source of OBDII code PO 0171, left bank lean, which I realize was not part of my original question. Anyways, I found a leaky air hose connection between the manifold and the MAF, once I corrected it, the engine idle smoothed out and now we have heat as designed at idle.
deeptread
- 171
- 1
- 1
- 5
