I'm running a BMW X1 AWD Xdrive with OEM 19" wheel spec staggered:
255 / 35 / 19 Rear 225 / 40 / 19 Front
Staggered tires height difference is -0.06" (approx 2/32", back tires have less height, I used https://www.discounttiredirect.com/learn/tire-size-calculator)
Tires are BFG G-force comp 2 A/S. When new, they are ~ 9/32, they have less than 10k miles.
I noticed that my rear tires wear in the middle is already 6/32 and ~7/32 on the sides. Front tires wear is 8/32 (!!) and a bit more than 7/32 on the sides.
It's my understanding that BMW cars are rear wheels bias, so even with Xdrive/AWD, the rear almost always wear first, specially in the center (due to quick acceleration and spirited driving).
QUESTION:
Should I keep running these until rear tires are 2/32 and change all 4, or I should change my rear tires already? I know that it's generally recommended to change all 4 tires on AWD, but since my front tires are almost new, and that that the rear is already -.06" height due to the staggered setup, I thought maybe I could start the next summer with brand new rear tires (currently running winter tires).
I'm afraid the rear tires continue to wear too fast, creating more than 1% of diff., which could maybe hurt the transfer case.
I would also have my current rear tires as good backups (since they are 50% used).
Thanks!
allaire
  • 277
