I want to use a floor jack to raise the front end of my 2005 Pontiac Vibe, so I can place jack stands on the pinch welds for an oil change. Where is a safe place to jack up the front of the vehicle with a floor jack?
2005 Pontiac Vibe front end
Is the circled area in red a safe place?
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
KyleL
  • 123
Use the rusty bolt at the top-center of the image. This puts it closer to the front and you won't be putting as much weight on your lifting point. While where you put the circle can probably take the increased load, it would be quite a bit more, considering it is closer to the center of the vehicle. The forward most of the two bolts which are attached to subframe should be a good lift point, because it will be solid there.
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
