I'm charging a flat battery with a mains charger. I'm curious if the mains charger can also be used to jump start... If it delivers enough power?
The instructions make no mention of this at all, did that mean even if it won't work, there's no safety concern?
Mr. Boy
  • 223
Presuming it's a standard "trickle" type battery charger and not a "jump pack", I wouldn't advise attempting to start a vehicle with the charger plugged in. The typical result, with a flat battery, is that the vehicle attempts to draw the power required to turn the engine over (the biggest ever demand on a car battery) from the low output charger and overloads the charger.
Steve Matthews
  • 23,464
  • 41
  • 92
You may be able to... if the battery is at full charge.
Best not try it. A battery charger delivers a few amperes at most. A properly charged battery delivers enough to turn over a starter motor or to melt a steel bar put between the poles.
(Hint: do not drop steel tools on both the + and - poles. If you are curious google on it instead).
The result is akin to a bucket of water slowly being filled from an outlet. The water bucket can deliver a lot of water in a short period. The outlet slowly fill it. If you try to drain a lot (water|amps) from the outlet then it will either blow a protective fuse or it will burn out.
Note that there is a distinction betweeen jump starters and regular chargers. I assume that with charger you either meant a regular charger or a trickle charger and not a jump starter.
Hennes
  • 589
  • 15
