I need Some opinions on 1992 prelude i have. Its the f22a1 5 speed . But I was coming home other day and going into 3rd and it made a odd banging noise then lost the gears. It wouldn't go into any gear. Had to push in the clutch and feather it to get car to move. I got it home and shut it off. Attempted to restart it and all I get is a humming noise. Won't even start now. Any idea's as to what it could be??
Asked
Active
Viewed 59 times
Given your description I think that you have a serious issue with the flywheel / clutch assembly. "Banging noise and no gears" so no connection from the engine to drive wheels...
Then when you try to start it, all you hear is a humming noise : this could just be the sound of the starter motor spinning.
So, you need to get a good mechanic (friend / neighbour if you are lucky...) to have a look and investigate further.
Best of luck...
Solar Mike
- 34,681
- 2
- 30
- 59
