I have 150k on my 03 Civic it has overheated several times. I can drive the car around town without it overheating, but when I drive it on the highway for an hour and it will overheat. I thought I had a blown head gasket turns out I do not. I pulled the car apart and pulled off the cylinder head. I took it to a machine shop and they checked it for flatness I got an okay from the machinist. I was told that if it was a cracked head that one of the cylinders would be steam cleaned. Nothing of the sort here. I am now left perplexed, what else could cause an overheating issue. I've had the water pump, stat, rad and fans checked and replaced. Two master techs suspected a small crack in the head gasket. Should i get a second opinion on the cylinder head being cracked? How about a cracked cylinder wall or a cracked block? How might one check for such things, such as tests. I poured blue devil engine sealant in this car before and it was a huge mistake. When I pulled off the head there was what looked to be white rock salt all in the cooling jackets and coolant holes. I got a lot of that out but not sure how to get the rest that must be in the cooling system. I pulled a big chunk of the sealant that was blocking up the thermostat. Before the sealant was put in the car, the car could run for an hour on the highway before overheating after the sealant it would run for a few minutes and overheat. This is probably due to the thermostat being completely blocked off by sealant. Here are pictures of the head gasket, the cylinder head, and the block.
https://m.imgur.com/a/5c4u4
Thank you
yre
  • 163
my 2003 honda civic has 211000 miles on it and has been overheating on fast highway driving, sporadically, for 10 years now. the other day it overheated, just as i arrived somewhere, in winter, so perhaps the problem is getting worse, which is great for EZ diagnosis. i have decided that it might have a hairline crack in the head that sometimes swells with heat (high speed driving) to lose coolant in a slight amount , which burns off and therefore is never seen. rather than spend a lot of time on what might be a fruitless search and replacement of various parts, i am going to be more proactive about checking the coolant levels before i start out , and by carrying enough 50-50 mixture when traveling.
sally
