I have a 2016.5 Mazda CX5 AWD which have run 1900 miles till now. Right front tire got a nail puncture. The nail is at the corner of the tire. Tire replacement shop told as nail is at side tire cannot be mended and it has to be replaced. Also, as it is AWD so all 4 tires need to be replaced.
My question is car is just 4 months old with 1900 miles, will it require all 4 replacement or only 1 will do?
pavel
  • 31
At 1900 miles, you'll only need to replace one tire.
Make sure the new tire is IDENTICAL to the other three. Ask the shop to measure the tread wear on the other tires, and to shave the new tire if the difference is outside the limits allowed. I think at 1900 miles, you won't even need to shave it.
If the tire replacement shop gives you a strange look when you ask them to consider shaving the tire, you're in the wrong tire shop. Put the donut spare on and go somewhere else.
If the tire replacement shop tells you that it's not possible to get an identical match for the tire, then again you're in the wrong place. Put the donut spare on and drive to the dealer.
Actually, it may be worth going to the dealer anyway; there may be some sort of warranty in place on the tires for a short while, or they may give you a goodwill benefit and cut you a deal on that new tire.
PeteCon
  • 8,722
  • 17
  • 30
Usually the reason to replace all 4 is because if all 4 tires are worn, then putting on one new tire which will be slightly taller due to it not being worn will cause the awd to "activate " causing some weird driving concerns. BUT if all 4 tires only have 1900 miles you should be ok if you get the same brand of tire. Do you have a full size spare? Also read your owners manual.
cano
  • 833
