I have problem with the front end on a 75 Duster. The front wheel on driver's side moved forward hitting fender in front of wheel. There is a half finger gap in front of wheel, three fingers behind. Just replaced upper control arm bushings, cam bolts, idler arm, and ball joint. The tire is still off center. Checked strut rod, bushings look good, and rod is straight. Everyone is saying the strut rod is causing the issue. Should I just replace it too?
Pᴀᴜʟsᴛᴇʀ2
  • 165,084
  • 32
  • 259
  • 508
tom
