My sister has a 1995 Chevy Lumina with the 3.1 liter engine. Her car tends to overheat at idle; we have determined that the radiator cooling fan does not kick on.
In our efforts to diagnose the problem, one possible solution appear to be a faulty ECT sensor. However, the dash gauge does work (that is how she determined it was overheating in the first place); as such, I am curious if this render a problem with the ECT sensor unlikely? That is, is the ECT sensor responsible for sending information to both the dashboard gauge and the coolant fans, or just the coolant fans? If the ECT sensor only controls the cooling fans, how does the vehicle monitor operating temperatures and send this data to the dashboard gauge?
Thanks.
KellyM
  • 461
The answer to your question is more simple than you may have thought. There are actually two separate sensors for this model. One is a sending unit that sends info to the gauge, not the ECU, which means that it's also possible for your gauge to give an incorrect reading or fool you into thinking the car is overheating when that's not the case at all and there's nothing wrong with the car at all (except for that sending unit being defective). The other is the ECT sensor that sends coolant temp info to the ECU in order to keep everything reacting appropriately. So yes, there could be a problem with the ECT sensor even if the gauge is operating properly.
Mustangguy809
  • 908
