The engine I'm rebuilding (Skoda Estelle/120, 70's, RWD, rear mounted engine) has a mix of different washers in its con rod bolts: some were tabbed washers, other spring washers... two or three bolts didn't have one whatsoever!
The engine was working just fine, however as I'm rebuilding it to a better state the question arises: should I only use tabbed washers for the con rod nuts, or can I use spring washers instead?
The fasteners are M8 x 1.25...the torque is to be between 18 and 20 lbs.
EDIT:
  • Tabbed washer, from catalog:
    Tabbed washer
  • Con rod nut, from catalog:
    Con rod nut
  • Parts catalog exploded view:
    Parts catalog exploded assembly
Zaid
  • 39,276
  • 50
  • 151
  • 294
Aram Alvarez
  • 3,376
  • 22
  • 43
I would use the tabbed washers : they don't affect the torque reading as once the nut is torqued, they bend easily and just lock the nut into place. Loctite - if available - may not always be effective if the parts are not clean. Tabs work if the parts are clean or dirty.
Solar Mike
  • 34,681
  • 30
  • 59
